Hello @lordmax
I do understand your position, but we still believe that portable version users may face issues due to the lack of some dependencies on their PCs.
I donāt understand.
There canāt be a ālack of some dependenciesā in portable software.
I almost exclusively use portable programs.
I use Firefox, Chrome, LibreOffice, GIMP, 7zip, Calibre, and various others.
They are all complex and comprehensive software programs and have no problems whatsoever.
In many situations, portable software is essential, for example when you have to use a system that isnāt your own and on which you canāt install other software.
There is NO reason why OnlyOffice canāt be portable, other than a lack of willingness to do so.
I work in an IT environment where portable software is essential. We canāt use OnlyOffice until itās portable, so obviously we use LibreOffice.
Dear @lordmax
Thank you for your feedback, weāre discussing the situation. I will contact you as soon as possible.
Dear @lordmax
We have started working on your suggestion and we have added it to internal tracksystem. I will update this thread once we have something to share.
Good news: go to ONLYOFFICE Portable | PortableApps.com and download OnlyOfficePortable_9.1.0_online.paf.exe. The online installer is 1.8MB. It works!!! To update it to version 9.2 is explained on the same page. It is a bit convoluted.
Hello @E.P
Unfortunately, we cannot recommend this installation since it hasnāt been tested. We will update this thread once we have something to share about the portable app.
