at least full screen gives some extra area
Hello, @Flapchap !
In ONLYOFFICE editors you can free up more space by hiding UI elements from the View tab: disable Always Show Toolbar (you can also just double‑click any tab to toggle the toolbar), and if needed disable Status Bar, Left Panel, Right Panel, and Rulers.
To make the document area larger, also use Fit to Width / Fit to Page (View settings / navigation tools) or adjust the Zoom slider.
It looks like you’re using a Nextcloud/ownCloud integration (please confirm). If so, this top frame/header is part of the integration/storage UI (Nextcloud/ownCloud page), not an element of the ONLYOFFICE Docs editor itself, so it can’t be hidden from the editor side.
Could you please clarify:
- what exact integration you use (uCloud/Nextcloud/ownCloud/something else)
- your ONLYOFFICE Docs (Document Server) version and the connector/app version
