Interface scaling
The interface scaling list is ridiculous . You jump 25 percent at a time and it can reach 500 percent , from which you can not recover.
offonly
The list should be (100%, 105%,110%, 115 %,120%--------- 145%,150%)
So it should jump 5% at a time, and stops at 150%.
Hello @shagi
Such incremental percentage is used widely across systems and other apps. Also, it grants clear display of the interface as the pixels do not mix in between themselves with such ratios. In other words, rendering an item with non linear scaling would cause it to be blurry.
