Interacting from editor (client-side) to plugin
Document Server version: 9.0.3
Type of installation of the Document Server: docker with onlyoffice/documentserver:9.0.3 image
Host OS: Debian 12 (Bookworm)
Browser version: Mozilla Firefox 128.13.0esr
I want to interact from the editor (browser - client side) to custom plugin. I’m using iframe.contentWindow.postMessage method to send a post message to editor’s iframe. By referencing sdkjs-plugins repository and it’s externallistener example the plugin implementation should look like this:
(function (window, undefined) {
  window.Asc.plugin.onExternalPluginMessage = function (data) {
    switch (data.type) {
      case "insertText": {
        Asc.scope.text = data.text; // export variable to plugin scope
        this.callCommand(function () {
          oParagraph.AddText(Asc.scope.text);
        }, false);
        break;
})(window, undefined);
I also registered my pluign properly to the following path
/var/www/onlyoffice/documentserver/sdkjs-plugins/insert_tool
Here is my postMessage call as an example:
    function onAppReady() {
      const editorIframe = document.querySelector('iframe[name=frameEditor]');
      editorIframe.contentWindow.postMessage({
        type: "onExternalPluginMessage",
        pluginGuid: "asc.{A8705DEE-7544-4C33-B3D5-168406D92F72}",
        data: {
          type: "insertText",
          text: "test text"
      }, "https://onlyoffice.example.local");
      console.log("ONLYOFFICE Document Editor is ready")
    editorConfig.events = { onAppReady };
    const docEditor = new DocsAPI.DocEditor("frameEditor", editorConfig);
what is the problem of my implementation ?
Hi @redcoder :wave:
Thanks for providing detailed information and code samples.
It looks like your issue is related to the onExternalPluginMessage behavior. Similar cases have already been discussed by other users in the following threads:
