Impossible to save a xlsx document in OO.9.4, but ok in OO.9.3
Hello everyone,
Unable to save an .xlsx file in ONLYOFFICE 9.4
Saving an .xlsx file is not possible in ONLYOFFICE 9.4 (x64-9.4.0.129).
Exporting to .ods format also fails.
With versions 9.3 and 9.2, saving works fine.
With version 9.4, if I remove the checkboxes (form objects), saving works.
How can I share the example file ? It’s not possible for new users.
Thanks in advance!
The previous fils isn’t downloadable anymore, here is the new link
Thanks in advance for help !
Thank you for providing the file. We tested it in ONLYOFFICE v9.4, but we were unable to reproduce the issue.
Please provide the following information:
  • Your operating system and its exact version;
  • The exact ONLYOFFICE product you are using;
  • The installation type;
  • The application in which the file was originally created;
  • The exact steps to reproduce the issue;
  • What happens when you save the file, including any error messages;
  • A short video demonstrating the issue.
Hello Marix, thanks for your help !
Here are the requested details.
Screenshots here : 3 files - storage.to
  • Edition : Windows 11 Professionnel
  • Version : 24H2
  • Build : 26100.1742
  • Experience : Windows Feature Experience Pack 1000.26100.18.0
  • ONLYOFFICE Desktop Editors
  • Version Community 9.4.0.129 (x64 msi)
  • Install file : DesktopEditors_x64-9.4.0.129.msi
  • Microsoft Excel
  • Open “fichier.xlsx” with ONLYOFFICE Desktop Editors Version Community 9.4.0.129 (x64 msi)
  • tick a box (circled in red in the Screenshot OO9.4-1.png)
    the problem is the same with all the checkboxes
  • File / Save As … fichier-2.xlsx (Screenshot OO9.4-2.png)
  • French message : (Screenshot OO9.4-3.png)
    Ce fichier ne peut pas être enregistré ou créé.
    Les raisons possibles sont :
  1. Le fichier est en lecture seule.
    2 Le fichier est en cours d’édition par d’autres utilisateurs.
  2. Le disque est plein ou corrompu.
translation :
This file cannot be saved or created.
Possible reasons are:
  1. The file is read-only.
  2. The file is being edited by other users.
  3. The disk is full or corrupted.
All these possibilities have been checked. The reason is something else.
If it helps, Gemini AI describe the origin of the problem lika this :
“This is a regression introduced in version 9.4. The new XML validation engine blocks saving whenever form controls (Excel/ActiveX checkboxes) originating from the original file are present.”
I hope you can find a way to save the file.
Thanks in advance !
Thank you for providing the detailed information and screenshots.
We have reproduced the issue and forwarded it to our QA team for further investigation. We will update this thread as soon as we have any news.
Hello @bmfr
If you don’t mind, I will join this thread as well.
We’re trying to reproduce the scenario, but without luck so far. Could you please try to remove the app and clear the cached data?
After that download new installer from the official site (Free office suite for Windows, Linux and macOS | ONLYOFFICE) and install the app again. Does the issue reproduce again?
Hello @Alexandre
Thanks for your help.
I removed the app. there is no option offered to “clear all user settings dans application cached data” during uninstalled.
So after uninstall I did :
Press Windows + R, type %localappdata%, and press Enter.
Locate the folder with the application’s name and delete it.
Repeat the process: press Windows + R, type %appdata%, press Enter . No folder with the application’s name found.
Then I installed the app from the link you gave and choosed “Online installer”.
Installed version is : Version Community 9.4.0.129 (x64 exe)
I tried again but the issue reproduce again.
Here is a video showing how the issue appears, file available during 6 days.
Sorry but my account can’t post links so I removed “http://” storage.to/be3D7nX37
Hi @bmfr,
Thank you for the video and the clean reinstall — very helpful.
We confirmed this issue in version 9.4.0 is related to saving files with Excel form controls (checkboxes). I’ve tested it on the upcoming version and the fix is already in place.
Until then, removing the checkboxes before saving works as a workaround, as you already found.
Hi @Nurullo
Do you know when the upcoming version is scheduled to go live?
Thank you for the information.
Hi @bmfr, unfortunately I don’t have an exact date — it is expected in autumn.
It’s good to know that a fix is planned for a future version. This is a serious issue: I lost several hours of work because there was no error message warning me that pressing Ctrl+S had not actually saved my changes. I encountered the issue on Debian 13 using OnlyOffice v9.4.0 flatpak.
To help test the fix, here is another example of an .xlsx file containing form controls that does not save correctly in OnlyOffice: https://assucopie.be/wp-content/uploads/2026/01/2026-Repertoire-litteraire-visuel-audiovisuel-sonore_Assucopie_Final.xlsx (sorry, I’m a new user and can’t attach files yet).
Hi @kirmaha, welcome to the community!
Thanks for the file. We checked it on our side and it saves fine on the upcoming version, so it looks like it’s covered by the same fix.
Sorry about the lost work.
Hi @bmfr, @kirmaha,
Quick update — version 10.0 is available and should include the fix for saving files with checkboxes. Please update and let us know how it goes! (For the flatpak version it may take a bit longer to show up.)
