I want Advice on Integrating ReactJS with Existing Projects
Hey All,
I have been working on a few web projects that are built with plain JavaScript & some jQuery but now I am planning to shift parts of them to ReactJS for better scalability & maintainability I have read a lot about how React can make the UI more dynamic & easier to manage but I am not sure where to start when it comes to integrating it into an existing codebase
I have also come across a few learning resources & even considered ReactJS Online Training to get a deeper understanding of hooks state management & component structure But before I jump in I want to hear from people who have done this transition What challenges did you face Did you rebuild certain parts from scratch or replace sections Any tips on tools libraries or workflows would be super helpful. Also i have check this Integration of onlyoffice web with my Prject still need your advice
Thank you.:slight_smile:
Regarding the integration of Onlyoffice Docs with a React project in particular, you can refer to this guide: React | ONLYOFFICE - it explains how it should be done. If you have any additional questions, feel free to ask.
And good luck with your training!
