I use the Desktop Editors 9.0.4.50 (x64 exe) on Windows 10 Pro 22H2.
I set a custom date format “yyyy/m/d” to a form control in a PDF, but it’s not working.
Hello @nishigaki
Please elaborate on how do you set a custom value. Basically, all currently available date formats are available in Form settings menu on right toolbar under Display the date like this section.
Hello @Constantine
I set a custom date format “yyyy/m/d” to a form control in PDF, but it’s not working.
as follows:
Thank you. It is plain PDF file, we will check this situation. Please await for the feedback.
The bug was registered on this behavior. Sorry for the inconvenience. I’ll update the topic once the issue is resolved.
Thanks @Constantine
I look forward to the fix.
Hello again @nishigaki
We have just released version 9.1 of the editors. Update for ONLYOFFICE Docs is available already, but for Desktop Editors it will be published a bit later.
Please await the update and check the situation again.
Thanks! @Constantine
That’s solved!
