Heyhey,
I am working with spreadsheets and would love to be able to create a hyperlink to a local folder and not just to a file.
Scenario:
I have a spreadsheet to keep track of my different projects.
Now I would like to click on a cell with a project name and have it open finder with the project location.
My specs:
- macOs 26.0.1
- OnlyOffice Version 9.0.4
Thanks!
Alex
Hello @GutmenschAlex
You can already do that by simply getting to the folder with your files after clicking on the folder icon in hyperlink settings window, selecting any file to generate a link and then removing the file name and the last slash to have a link to the folder.
Upon first opening you may be prompted to allow access to the storage, which is required to open a directory.
Perfect, that is exactly what I need. Thank you!
