Faulty installer script
I think the script is broken for ubuntu 22.04 for both docker and .deb
I have attempted to install all day clean build and this is the output for ubuntu with dock
WARNING: This output is designed for human readability. For machine-readable output, please use --format.
Docker image mysql:8.0.29 not found
I can’t post the output as the forum won’t let me
when you install on a clean machine and try to run .deb their is errors for failed SQL Keys and mono installer error and then it bombs out
this is the output from the workspace installer script, the same on ubuntu 22.04, 24.10 and Debian 12 & 13
Same thing here: root@ubuntu-server:~# bash workspace-install.sh -it WORKSPACE -ims false -cp 8080 -mk machinekey -u true
Select ‘Y’ to install ONLYOFFICE using Docker (recommended). Select ‘N’ to install it using RPM/DEB packages.
Please note, that in case you select RPM/DEB installation, you will need to manually install Mail Server and connect it to your ONLYOFFICE installation.
See instructions in our Help Center: http://helpcenter.onlyoffice.com/server/docker/mail/connect-mail-server-to-community-server-via-portal-settings.aspx
Install with Docker [Y/N/C]? Y
8.0.29: Pulling from library/mysql
Digest: sha256:152cf187a3efc56afb0b3877b4d21e231d1d6eb828ca9221056590b0ac834c75
Status: Image is up to date for mysql:8.0.29
Docker Hub Container Image Library | App Containerization
root@ubuntu-server:~# root@ubuntu-server:~# bash workspace-install.sh -it WORKSPACE -ims false -cp 808bash workspace-install.sh -it WORKSPACE -ims false -cp 8080NLYOFFICE using Dockeroot@ubuntu-server:~# bash workspace-install.sh -it WORKSPACE -ims false -cp 8080 -mk machinekey -u true
Out of curiosity I did this with the enterprise script and same error
@here, we are aware of this issue. More details you can find here:
the Docker version works however the Debian one fails with mysql outdated key
https://dev.mysql.com/get/mysql-apt-config_0.8.35-1_all.deb run this and it fixe the key
Please try again, there is new update has been released.
