Enhancements regarding fields
Hi!
Idea
I would love to propose IntelliSence feature to fields. When user presses Ctrl+Space either all possible fields are shown or (if field name is already entered and a cursor is after it) its parameters.
How I expect it to look like
I made this picture in OnlyOffice to demonstrate the design I expect from this feature:
Notes
  • Field flags should be suggested by Ctrl+Space just in case if conditions to use them are met.
  • Flag arguments are expected to be completed to.
  • Regular arguments like Bookmark of REF field should also be completed.
I understand that it may be hard to implement, but it can make fields much more usable. I expect the same or close assistance formulas in excel have when typing them regarding fields.
Hi!
Thank you for your detailed suggestion and the screenshot. We have registered it as a feature request for the Document Editor and forwarded it to our team for consideration.
We will update this thread if there is any news regarding its implementation.
We have registered this feature request in our internal tracker.
