Document adds white space
It looks like a bug. But maybe I just don’t know about some specific settings.
I must say that previously I wrote about this problem in neighbour conversation, but that time I mistakely decided that the problem was solved. After few weeks I see that solution was partial. It doesn’t fix the root of the problem. Even if I change in “Paragraph advanced settings” checkboxes for: “Orphan control”, “Keep lines together”, “Keep with next” that settings applies at the moment I do it. But during the next work with this document the problem appears many times especially with tables. I demonstrated it in a second video. It looks like the program losses its settings for some reason during editing.
I’m attaching a video demonstration and a file that has the problem.
Договір із залученим викладачем.docx (55.0 KB)
My previous conversation about this problem: Lots of empty space on some pages in Document (white space)
This problem is very annoying. During the previous three weeks I prepared more than 50 documents in OnlyOffice. I met this problem in every document, few times in each document, especially with the tables.
Hi @Golembivskyi,
In your video we see that only “Keep with next” was unchecked, while “Keep lines together” and “Orphan control” remain enabled — these can also push content to the next page and create the white space.
Please select the text and uncheck all of them in Paragraph Advanced Settings → Line & Page Breaks.
On our side this removes the white space. Also note that MS Word behaves the same way with these settings.
Let us know if this helps.
