Hi folks, first post! I’m trying to install DocSpace Developer on a freshly installed Redhat 8.10 (Ootpa) box via the command below. I cannot run this in Docker as it’s not an approved technology in the very strict environment that I work in.
Essentially the script is trying to install a REL10 package on a REL8 VM. Any insight would be appreciated!
Thanks,
Adam
OS Info
[root@onlyoffice DocspaceDeveloper]# cat /etc/redhat-release
Red Hat Enterprise Linux release 8.10 (Ootpa)
Linux onlyoffice 4.18.0-553.89.1.el8_10.x86_64 #1 SMP Sat Nov 29 00:49:18 EST 2025 x86_64 x86_64 x86_64 GNU/Linux
Log of install
[root@onlyoffice DocspaceDeveloper]# bash docspace-developer-install.sh package
BOOTSTRAP
net-tools-2.0-0.52.20160912git.el8.x86_64
CHECK PORTS
INSTALL PREREQUISITES
Updating Subscription Management repositories.
17 files removed
onlyoffice repo 23 MB/s | 27 MB 00:01
Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs) 44 MB/s | 116 MB 00:02
Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs) 38 MB/s | 78 MB 00:02
Last metadata expiration check: 0:00:03 ago on Wed 17 Dec 2025 08:51:39 AM EST.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
yum-utils noarch 4.0.21-25.el8 rhel-8-for-x86_64-baseos-rpms 76 k
Transaction Summary
Install 1 Package
Total download size: 76 k
Installed size: 23 k
Downloading Packages:
yum-utils-4.0.21-25.el8.noarch.rpm 229 kB/s | 76 kB 00:00
Total 229 kB/s | 76 kB 00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : yum-utils-4.0.21-25.el8.noarch 1/1
Running scriptlet: yum-utils-4.0.21-25.el8.noarch 1/1
Verifying : yum-utils-4.0.21-25.el8.noarch 1/1
Installed products updated.
Installed:
Complete!
Last metadata expiration check: 0:00:17 ago on Wed 17 Dec 2025 08:51:39 AM EST.
Last metadata expiration check: 0:00:20 ago on Wed 17 Dec 2025 08:51:39 AM EST.
Retrieving https://dl.fedoraproject.org/pub/epel//epel-release-latest-8.noarch.rpm
warning: /var/tmp/rpm-tmp.4wmu2A: Header V4 RSA/SHA256 Signature, key ID 2f86d6a1: NOKEY
Verifying… ################################# [100%]
Preparing… ################################# [100%]
Updating / installing…
1:epel-release-8-22.el8 ################################# [100%]
Many EPEL packages require the CodeReady Builder (CRB) repository.
It is recommended that you run /usr/bin/crb enable to enable the CRB repository.
Extra Packages for Enterprise Linux 8 - x86_64 10 MB/s | 14 MB 00:01
Last metadata expiration check: 0:00:03 ago on Wed 17 Dec 2025 08:52:05 AM EST.
ladspa-1.17-6.el10_0.x86_64.rpm 106 kB/s | 44 kB 00:00
Error:
Problem: conflicting requests
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by ladspa-1.17-6.el10_0.x86_64 from @commandline
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by ladspa-1.17-6.el10_0.x86_64 from @commandline
(try to add ‘–skip-broken’ to skip uninstallable packages or ‘–nobest’ to use not only best candidate packages)
An error occurred while executing the script. Log saved to: OneClickinstall-RedHat_20251217_085114.log
