Desktop-editors: Character styles are not supported
Onlyoffice writer does not support character styles at all and that’s a quite big limitation for productivity. When *.docx files, written with other office program suites (word, libreoffice, wps office) are open in OnlyOffice, such styles are imported , but not recognized as such (character styles) and applying them to selection of text result in formatting the whole paragraph, not the selected text.
Cheers
Hello @naut1905
Can you provide more information about “character styles”? For instance, a link to the documentation that describes them as a feature.
Hi, character styles are - as the same word suggests - styles that appiy to a specific portion of text (opposite to paragraph styles which apply to a whole paragraph). They are a common feature in all office suites word processoes (MS word, WPS word, libreoffice writer, etc.). So far it is not possible to CREATE them within onlyoffice. It is possible just to “import” them from a .docx file created with the above mentioned office suites.
Cheers
Thanks for clarification. Such feature was suggested before here:
I am also adding your query to the existing suggestion.
