CRM CSS problem?
Hello. I have newest community workspace installed without mailserver. I used Debian latest with install script. Everything works fine. Only CRM has problém that menu looks like there are huge icons and something is broken. I dont have image right now but maybe someone knows what this could be… Thank you.
So here is an image:
Hello @NewOfficer,
Please try removing the bundle directory here:
/var/www/onlyoffice/Data/bundle/
After that execute systemctl restart monoserve and check if the issue persists.
Sorry but there is no WWW folder in VAR
in APP/ONLYOFFICE there is:
so I have something in: /app/onlyoffice/CommunityServer/data/bundle
is this what you mean?
I shuld Delete whole BUNDLE directory?
Thank you
PLUS yet another thing:
Failed to restart monoserve.service: Unit monoserve.service not found.
For a docker installation, you need to execute the above steps in the Community Server container.
OH, it really helped. Thank you so much.
In your opinion. Is it better to use docker or no if I can dedicate whole VPS to onlyoffice?
In general, a docker installation is easier to deploy and update, so I’d recommend sticking to docker.
Thank you. May I have yet another question here?
Is it possible to link case with company or contact the way I will also see which cases has company or contact? Because now I can connect them but there is nothing about cases in company or contact…
And second question - can I change menu or some items name in my language? Of course it will be overwritten by update but is there such possibility?
Thank you.
Hello @NewOfficer
Please start two new topics for these questions to avoid discussions of several topics in a single thread. I’d be much appreciated, thank you.
