Columns in Documents
In my document I would like to change the column gap for the entire document.
Currently I have to go to Layout-columns-more… And set to 2 and the column gap.
Would be great to have a checkbox: Make default
Hello @Torsten
Have you encountered any processor that have such checkbox?
Sorry - no.
But in MS Word you can apply the spacing to the whole document, which basically does the same.
I see, thanks for the reference. We need some time to discuss your suggestion, please await a feedback.
Your suggestion has been registered, the number is 79362. I will keep you posted on the updates.
