Document Server version:
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS: LINUX MINT
Browser version:
Additional information:
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
If I select more sheets I cannot change simultaneously a cell content in all selected sheets, as in Excel or LibreOffice
Hello @vinicio.dannunzio
Do you mean selecting a cell, for instance, A1 and then selecting several sheets to type a value in?
Yes, that’s what I mean
Thanks. Indeed, this possibility is not implemented. We need to discuss this enhancement internally, please await my feedback.
Thanks, I hope you will implement this function. It’s really time sparing when you work on many sheets at the same time.
Best regards
It has been added into internal bug-tracker under the number 57532. Thanks for the interest.
