callbackUrl 配置不生效 一直显示为true
我用的是 onlyoffice-documentserver-7.1.0.aarch64.rpm 镜像
版本比较老 因为机器是麒麟v10的 不能用docker部署
我现在的问题是 我前段写的callbackUrl不生效,
我的配置:
initEditor() {
  const fileUrl = "http://xxx.xx.xx.xx:8088/files/temp/10006680002/测试文档.docx";
  const callbackUrl = "http://xxx.xx.xx.xx:80/data/resource/directory/onlyOffice/callback";
  console.log("fileUrl:", fileUrl, typeof fileUrl);       // string
  console.log("callbackUrl:", callbackUrl, typeof callbackUrl); // string
  new window.DocsAPI.DocEditor("onlyoffice-editor", {
    document: {
      fileType: "txt",
      key: "10006680002",
      title: "测试文档.txt",
      url: fileUrl
    editorConfig: {
      mode: "edit",
      lang: "zh-CN",
      region: "us",
      coEditing: { autoSave: 60 },
      customization: { forcesave: "true" },
      permissions: { edit: true, save: true },
      user: { id: "10000430036", name: "测试用户" },
      callbackUrl: callbackUrl ,
    height: "100%",
    width: "100%"
报错内容:
[2025-10-21T09:15:40.234] [ERROR] nodeJS - postData error: docId = 10006680002;url = true;data = {"key":"10006680002","status":4,"actions":[{"type":0,"userid":"10000430036"}]}
Error: Invalid URI "true"
    at Request.init (/snapshot/server/build/server/Common/node_modules/request/request.js:273:31)
    at new Request (/snapshot/server/build/server/Common/node_modules/request/request.js:127:8)
    at request (/snapshot/server/build/server/Common/node_modules/request/index.js:53:10)
    at /snapshot/server/build/server/Common/node_modules/request/index.js:61:12
    at Function.post (/snapshot/server/build/server/Common/node_modules/request/index.js:100:12)
    at /snapshot/server/build/server/Common/sources/utils.js
    at new Promise (<anonymous>)
    at Object.postRequestPromise (/snapshot/server/build/server/Common/sources/utils.js)
    at sendServerRequest (/snapshot/server/build/server/DocService/sources/DocsCoServer.js)
    at sendServerRequest.next (<anonymous>)
    at sendStatusDocument (/snapshot/server/build/server/DocService/sources/DocsCoServer.js)
    at sendStatusDocument.next (<anonymous>)
    at cleanDocumentOnExitNoChanges (/snapshot/server/build/server/DocService/sources/DocsCoServer.js)
    at cleanDocumentOnExitNoChanges.next (<anonymous>)
    at closeDocument (/snapshot/server/build/server/DocService/sources/DocsCoServer.js)
    at closeDocument.next (<anonymous>)
[2025-10-21T09:15:40.903] [ERROR] nodeJS - Error openDocument: docId = 10006680002
TypeError: undefined is not a function
    at /snapshot/server/build/server/DocService/sources/canvasservice.js
    at Generator.next (<anonymous>)
    at onFulfilled (/snapshot/server/build/server/DocService/node_modules/co/index.js:65:19)
    at runMicrotasks (<anonymous>)
    at processTicksAndRejections (internal/process/task_queues.js:95:5)
你好 @shuchen
感谢你提供详细的错误日志和配置。然而,我们无法为OnlyOffice文档服务器版本7.1.0提供支持,因为该版本明显过时且不再受支持。请升级到最新版本(9.1)。
升级到受支持的版本后,我们将很乐意帮助排查任何剩余问题。
