I’m trying to assign the Asc.scope.eq variable to the text in the math equation field the cursor is currently in.
I want the variable assigned before the evaluatex() function is called.
(function (window, undefined) {
window.Asc.plugin.init = function () {
Asc.scope.eq = "2+2"
// Somehow assign Asc.scope.eq to the text in the math equation text field the cursor is in
var fn = evaluatex(Asc.scope.eq);
var res = fn().toString();
var sScript = "var oDocument = Api.GetDocument();";
sScript += "oDocument.AddMathEquation('" + res + "');";
this.info.recalculate = true;
this.executeCommand("close", sScript);
})(window, undefined);
I’ve been trying to find a solution for a few hours now, but I’m really struggling.
Any help is appreciated
Thanks in advance!
Hello @Pineapple0000
I’m not sure that this approach is possible. It seems that you can use GetSelectedContent method (GetSelectedContent | ONLYOFFICE) to achieve the same scenario.
Please clarify if I misunderstood the request.
Hi @Alexandre
I have attempted to do that, but I can’t find an implementation that successfully assigns the selected text to the variable
Do you think you could write an example?
Thank you
we’re looking into it. I will contact you as soon as possible.
It seems that this method works this way:
window.Asc.plugin.executeMethod("GetSelectedContent", [{type:"text"}], (text) => {
console.log(text);
window.Asc.scope.eq = text;
However, you need to select the formula in the field first. I’m not sure how to achieve this at the moment. I’ve found my old plugin sample and a video test, which might be useful for your research (it selects all data in the file; I’m not sure if it still works, but it could still be helpful). I’ll send it to you via PM.
