Addition of new but important feature in onlyoffice spreadsheet for Data Entry
Thanks for your response. By “Data Form dialog,” I’m referring to the feature in Microsoft Excel that allows users to add, edit, and search records in a table through a pop‑up form.
Here’s the official documentation for reference: { Add, edit, find, and delete rows by using a data form - Microsoft Support. }
I think adding a similar feature in ONLYOFFICE would make data entry much easier, especially for large tables, since it avoids scrolling and provides a cleaner interface for non‑technical users.
Hello @SkReyazAmin
Your suggestion has been registered. It will be available in one of the future versions of editors.
