About cann't adding a local ollama llm in ai agent
I have deployed DocSpace in an offline environment (Windows Server 2019) and manually installed the AI plugin. The plugin works fine when adding a local Ollama LLM within documents. However, there is no Ollama option in the AI Agent settings. Furthermore, the URL field is uneditable under other options. Could you please advise on how to resolve this? Thank you!"
Hello @balence
As I can see, you have resolved the issue with AI plugin, is that correct? You have posted one separately here: In an offline environment, the plugin manager page is not accessible. While mounting the plugin directory allows plugins to be listed, the AI icons fail to display, and configuration is unavailable
Please confirm.
About the agents: can you try selecting any other provider? On the very first screenshot you have OpenAI, can you change to any other one?
